gas tank/manifold
mike mcmurray
11-23-2005 05:28:53
Just curious as to the best way to clean out a gas tank. I heard of something, but forgot the name, that cleans, protects and seals the interior. Is this a good product and what is it called? Also, the manifold is cracked and in two pieces. I am going to braize or ni rod it to become one again. However, I would also like to clean out some of the rust and crap before bolting it back to the engine. I read somewhere that vinegar will eat away at the rust. If I soak it in a vinegar solution, will that help prevent any of the looser rush from entering the engine once I get the engine fired up.....Any input would be appreciated. I also need a rear 12 inch rim. Any ideas of where I might find one? Have a great holiday. Mike McMurray
CK RICHARD
11-23-2005 16:13:03
 Re: gas tank/manifold in reply to mike mcmurray, 11-23-2005 05:28:53
mike I use REDKOTE it will sill cracks holes and rust, just one step and not hard to do ,drys over night .had alot of trouble with my SC before the redkote .been in there for 6years
L.C.Grey
11-23-2005 12:43:45
I also recommend the gas tank sealing system from Eastwood. I've used it on several tractor tanks and have been very pleased with the results. Plan on spending most of an afternoon and wear your work clothes because it can tun into a full contact sport wrestling with the larger tanks. I found the product will fill and seal some pretty good size pinholes without any repair beforehand. The only thing I'd add is that if you are doing a large tank, say maybe over 15 gallons, I'd order an additional bottle of sealer to get a more thorough coating.
Larry Martin
11-23-2005 11:21:42
If your working on a DC I have a near perfect tank with no dents, rust, or varnish.
Bob/wis
11-23-2005 10:29:54
Mike,
What model of tractor are you working on? And what size of rim do you need?
Bob
Paul f
11-23-2005 05:47:54
Eastwood sells a gas tank repair kit that I have used several times on tractors, old military vehicle and small generators. It seems to hold up well. It is an messy project multi step project. They provide three items and you have to locally procure muriatic acid and acetone.
