I just did it - no problem.
jdemaris
11-22-2005 06:34:29
I recently replaced the 188D engine in my 580CK backhoe/loader with a 207D. They are exactly the same dimentionally - no problem at all. The changes I had to make had nothing to do with the engine models - it was more related to the application of each engine. Regardless if the engine is a 188D or a 207D, they are both available with cast oil-pans, thin steel oil pans, one piece timing covers, two piece timing covers, and various intake and exhaust manifolds. Since the engine blocks are dimensionally identical, it is no problem switching accessories from one engine to the other. In my situation, I had a old 580CK with a 188D using a one piece timing cover, a wet 12 volt starter, and a cast-iron oil-pan and also a cast-iron intake manifold. The 207D came from a military forklift and had a thin sheet-metal oil pan, a two piece soft-metal timing cover, a dry 24 volt starter motor, and soft-metal intake manifold. I simply swapped the necessary parts and all went fine.
