pto problems
jms
11-21-2005 18:37:44
I have a 630 case o matic with some pto problems
when you hook up a brush hog and enguage the pto it will run but when you get into grass the pto stops.also when the tractor is just running with the pto disenguaged it will not stop. the spring that is the adjustment is as tight as it will go. please help how do you adjust?
John Saeli
11-22-2005 11:58:15
 Re: pto problems in reply to jms, 11-21-2005 18:37:44
2 things sound like are going on here. The Clutch Pac sounds like it's not adjusted up tight enough, causing the slip under load, but the Discs are warped causing the Drag. That pack is adjusted by pulling a Pin inside the housing, and turning the collar to tighten the Pac up. Good Luck
Mathias NY
11-22-2005 06:28:49
Are you sure the PTO stops turning on the tractor end and not on the mower end? I have seen before where the clutch on the mower will slip under load.
