Case model 23 loader bucket dump cylinder
Chuck59
11-21-2005 09:01:23
I have a 430 Case with a model 23 loader. I beleive this to be an industrial version. The bucket dump cylinder is leaking alot and the rod doesn't look to be in the best condition. I'm looking for repair options (new parts $800+)or to locate a complete used cylinder. Was this cylinder used in any other applications that i can look for?
jr @beaver machine
11-23-2005 05:49:11
 Re: Case model 23 loader bucket dump cylinder in reply to Chuck59, 11-21-2005 09:01:23
I have a few industrial tractors I will part out. There is a 530ck, 430ck, and a 480. I will look to see what shape the bucket cylinders are in and repost if I have a good one. I will have no way to check if they leak, but if the barrel and rod are good, a kit could to put in. JR
Mike Johnston
11-21-2005 13:30:52
I don't know the particulars on that cylinder, but you may be able to find a comparable replacement at NorthernTool.com. They have a huge selection of hydraulics.
Chuck59
11-21-2005 13:50:28
 Re: Case model 23 loader bucket dump cylinder in reply to Mike Johnston, 11-21-2005 13:30:52
The cylinder does not attach on the end, instead it mounts into the bucket linkage with trunion bearings on each side of the cylinder. I will check to see if they have a similar type mount, but think it's a Case part only....
