distributor cap
INCase
11-21-2005 05:02:55
I have an 800 with the autolite distrib. how do you remove the cap/plate inside under the dist. cap under the rotor. It looks like it has bumps on it for gripping and turning but I can't get it to move. Is the Wico a better distributor? Can you get parts for either of these? It looks like the rotor on the Autolite is a modified rotor from something else. Thanks.
Cases n Harleys
11-22-2005 06:25:40
 Re: distributor cap in reply to INCase, 11-21-2005 05:02:55
I have the same problem with My 51 vai I usually set a flat tip screwdriver under one of the protruding flats and lift straight up, Had the blood running first time, she had set for a number of years.
John Saeli
11-21-2005 17:21:38
That dust shield should lift out. The Parts for the Wico are extremely expensive. I'd say you're better off with the Auto-lite.
INCase
11-22-2005 06:01:16
 Re: distributor cap in reply to John Saeli, 11-21-2005 17:21:38
Thanks. I will try to "lift" the cover out and see what I've got. From what i've seen/heard they made alot fo wico's but the parts aren't real handy. I also read that some have converted from wico to Delco's. thanks again
Glen in TX
11-22-2005 14:55:25
 Re: distributor cap in reply to INCase, 11-22-2005 06:01:16
I still have some NOS & new Wico DB distributor parts and they aren't no worse than others and still available new.
