cambolted toomanycases
wilson
11-20-2005 19:40:32
Ted where are you now?? posted message last week as I located 2 more dc eagle hitches Fellow may be a little hard to deal with but there are just stuck and setting same spot for years . How many dc eagle hitch tractors does GOD need?? Hey toomany cases what do you need out of parts pile in colorado???
Camboted
11-21-2005 01:52:03
 Re: cambolted toomanycases in reply to wilson, 11-20-2005 19:40:32
Wilson, I am back in Cambodia, but have been traveling in the provinces. Managed to survive a plane crash this morning, so I'm happy to be here. I am interested in the tractors. we could use some more. Where are they located? Email me with any details: [email protected]
grapefarmer
11-21-2005 06:34:21
 Re: cambolted toomanycases in reply to Camboted, 11-21-2005 01:52:03
Glad you are OK!
John Saeli
11-21-2005 04:14:21
Het Ted: Tell us about the plane crash!!
Camboted
11-21-2005 16:42:00
 Re: cambolted toomanycases in reply to John Saeli, 11-21-2005 04:14:21
third party image
John, it was a Russian designed, Chineses built prop plane from the 1960's that we use to access a dirt stripped airport in the very NE corner of Cambodia. The bone-heads had the plane overloaded, with about 60 passengers in a 52 seat palne and packed with cargo to boot. The old bird came down hard on landing. The gear collapsed on one side and spun the plane around putting it into a grove of trees on the side of the runway, the nose wheel then broke off and one engine started to burn the grass around the plane. Adds a little excitement to the day. Only two slight injuries.
CASEPOWER
11-22-2005 06:08:13
 Re: cambolted toomanycases in reply to Camboted, 11-21-2005 16:42:00
Wow, you get the paper a day early!! How about giving me some Thanksgiving day scores the day before Thanksgiving... Heehee
wayne2
11-21-2005 20:33:31
Praise to the higher power!!!
toomannycases
11-20-2005 20:37:44
Wilson, I would like the transmission brake lever assembly, mounting bracket, lever,brake band assembly and linkage. Also the belt pully assembly as it bolts onto the shaft. My 39 DC has the casting for trans brake broken off & missing the lever etc. Also some one put the wrong belt pully on it, measures 14.5" if I remember correctly. I have to go to Devner to pick up a CC in the next few weeks & I could get the parts if you agree to it & the costs of them. Thanks Chuck
wilson
11-21-2005 07:12:08
 Re: cambolted toomanycases in reply to toomannycases, 11-20-2005 20:37:44
Chuck I would like the rear quills (axel housings ) and the transmission cover steering shaft assembly . As fas as I am concerened if you will continus to help Ted when you can the rest of the tractor is yours. I think I still have your phone will call. Where are you located as I would like to find a mutual place to recieve the parts I want.---- Ted glad you are apparently ok. I will try to deal with the fellow but he said he could price till after turkey day. Will e mail you detatils. Bill
