lp fuel problems
tinman700
11-19-2005 15:14:02
I have a 900lp and Im having trouble getting it running. It has sat for about 4 years, and after a regulator rebuild it still wont run. It will fire when you first try to start it, but after that its like its starving for fuel. Carb looks fine also. Any ideas would be great.
david sprague
11-22-2005 05:13:15
 Re: lp fuel problems in reply to tinman700, 11-19-2005 15:14:02
make sure your getting air take your oil bath off or just take your air intake hose off
Joe Peeper
11-19-2005 18:39:51
Remove the LP filter and see if it is plugged. That may be the problem.
Camboted
11-19-2005 15:27:23
If it has been sitting that long you may want to pull the valve covers and see if you have valves that are stuck.
