flushing engine
mike mcmurray
11-19-2005 14:28:12
I got a case 310 utility tractor and finally got the engine broken loose. Tomorrow I am going to flush the engine with diesel (with oil pan on) and crank by hand....then drain....then do the same, etc, etc..... Should I leave the rocker assy on or off.? Does it matter? Any other info would be helpful. My plan after this is to attach everything back on and try and fire her up....then I can test compression, etc. Thanks
Joe (Wa)
11-19-2005 17:11:58
 Re: flushing engine in reply to mike mcmurray, 11-19-2005 14:28:12
Personally I think trying to flush the lubrication system with diesel is a waste of time if not detrimental. You are not likely to move much, if any, diesel cranking by hand. Certainly not enough to �flush� the system. Even if you use the starter to crank, the debris will end up packed in the smallest clearances as in the bearings.
Joe
