Case 500/511B drawbar
FrankxR
11-19-2005 05:11:27
Could someone help with the size of the swinging drawbar on this tractor. (this is the one that has a support with many holes in it in a semi circular arc and does NOT have a roller to support the draw bar) Someone did a real chicken scratch welding job on the part that holds the draw bar on the support slider so I am in the process of cutting it off and reattaching it properly. The draw bar I have looks like it might be too thick and wide because it does not swing very far over the support slider. I need the thickness and width of of the main draw bar as well as the thickness and width of the piece welded on top of it that allows it to hang from the semi circular support. Additional question, from the appearance in the parts manual it looks as if there is a piece of angle or channel welded to the bottom of the drawbar. Could you confirm this? What size of channel or angle is this. Mine does not have this.
wayne2
11-20-2005 16:31:22
 Re: Case 500/511B drawbar in reply to FrankxR, 11-19-2005 05:11:27
If that bar swings easily-shouldn't be a prob. Mine(310,411 others)held in place by any ol bolts that fit in hole. Angle iron under bar is a stiffener-not really nessary for any practicle use ae pulling(even if uncle Fred 480pds wants to jump up and down on it) LOL W
