Case 310 bad shuttle shift How big is the job?
farmbob
11-17-2005 09:01:38
I found a case 310 with loader owner claims there is a bad shuttle shift. How big is the job and what do the parts run. I have never touched a case. But do have repair know how.
CH
11-17-2005 21:11:08
 Re: Case 310 bad shuttle shift How big is the job? in reply to farmbob, 11-17-2005 09:01:38
Is this a wheel tractor or a crawler?
mike mcmurray
11-17-2005 15:25:58
I can not help you with the shuttle shifter (atleast yet), but I just recently pulled a 310 out of a field up here in new hampshire. Finally got the engine unstuck after about two weeks..... will try a couple gaskets for the oil pan and the valve cover, and then try the compression. If there is anything you can share with me that would be great. I can keep you posted to if I find anything I think may be valuable. Good luck with your find. Is the 310 common....don't seem to see many of these posted here. Take care, Mike McMurray
wayne2
11-18-2005 19:21:01
 Re: Case 310 bad shuttle shift How big is the job? in reply to mike mcmurray, 11-17-2005 15:25:58
Had shuttle on 320 b/hoe, my 310 had hand clutch/sorta! it would pull out but needed foot clutch to reset it. Wayne
