SC Rocker Arm Oil
Jiver
11-17-2005 08:32:06
Recently I adjusted the valve lash on my SC. Prior to putting the valve cover back on, I ran it for a while to see if I had oil flow. I had oil flowing around the lift rods, but not much anywhere else. Should there be oil flowing around the rocker arm shaft or at the tappets where they hit the valve stems? Thanks.
Rahlo
11-20-2005 20:55:55
 Re: SC Rocker Arm Oil in reply to Jiver, 11-17-2005 08:32:06
There will not be a lot of oil at the pionts you've described but what is there is sufficiant to lube the low rpm engine.
