Case LA hp
Timothy
11-16-2005 16:26:53
I have a 1948 LA and rebuilding it, would like to get more horses out of it, looking for ways to do that and places to get parts.
Paul D
11-21-2005 19:00:03
 Re: Case LA hp in reply to Timothy, 11-16-2005 16:26:53
Dads LA is bone stock on an unrebuilt powerunit motor stock rpms with the spark lever set just right it will run 103hp. Id put on the LP head and anjust the rpms a little and it'l go real nice.
Walt Davies
11-17-2005 09:00:02
There are lots of options to increase the Hp on your LA. It mostly depends on what you want to spend and how much HP you want.
1. mill head to raise compression to 8.0 to 1 Or get an LP head and then mill pistons to fit or get Lp pistons. 2. go to oversize pistons and sleeves.
3. there are stroker kits that you can get you can bore and stroke out to 1200 CID you will have hunt around to get this info as the guys who do it are pretty quiet about how they did it. But its cost like hell and will really add the HP.
The head LP is the best way for a small amount of HP increase at a reasonable price, that's what i did.
Walt 503 623 0460
