DB 990 leaking front and rear main seals
Wendell Hobbs
11-16-2005 10:00:40
I have an early model DB 990 (1965). It runs good but has a serious leak at the rear main seal and a seep around the front main. Is it possible to replace/repair these seals thru the oil pan without removing the engine? If so how?
Hate to remove engine just for the seals.
baz
11-16-2005 22:18:14
 Re: DB 990 leaking front and rear main seals in reply to Wendell Hobbs, 11-16-2005 10:00:40
You can remove the radiator and front crank pulley to change the front seal. Check the seal area of the pulley. To replace the rear crank seal, you need to split the tractor at the clutch, remove clutch and flywheel to get to seal housing. It is an alloy two piece housing with a half round seal packing in each. Early Perkins engines are similar.
Check your engine breather is clear first.
Barry.
