Case L vs LA
Simply Puzzled
11-14-2005 22:20:23
What is so different between the L and LA that gives the LA more power. I have a 1936 L and compete against a few L's and LA's in local pulls. Us L guys are pretty close to each other but we simply can't get close to the LA's. We all have FIRESTONE F&R tires which are even the same size. The L powers out. The LA spins out. Any ideas out there!
RobertTX
11-15-2005 19:26:33
 Re: Case L vs LA in reply to Simply Puzzled, 11-14-2005 22:20:23
Actually the biggest difference is the pistons. The Standard L pistons are at TDC about 1/4 inch below the deck, the standard LAs are at deck height. I don"t remember if it is the pistons or rods, almost 100% sure it is the pistons. Both used dual fuel head 4447, if you can get higher compression pistons from LA and a LA propane head, you can go after your friends. Next problem will be weight. If you have cutoffs, they will have a lot more traction with the heavy cast hubs. Good luck.
RobertTX
King case
11-15-2005 03:44:31
The only major diffrence in the LA engine is cylinder heads. You have higher compression heads available on LAs. They will fit right on to a L. Then there were over bore kits that would fit in both. Hope this helps.
