DB990 radiator swap,question for Elmer?
justyl
11-14-2005 20:01:19
Wanting to know if a radiator from a 1290 will work in a 990 ? Curios if anyone else has tried this,cause I have access to a good rad. from a 1290 that is being tore down due to an early axle casting malfunction. Any input appreciated,thanks.
Baz
11-16-2005 22:49:57
 Re: DB990 radiator swap,question for Elmer? in reply to justyl, 11-14-2005 20:01:19
A 1290 radiator has different mounts. The mounting plates run down the outside of the chassis with the bolts running horizontal through the mount and chassis. The radiator is smaller in size but they got around that by using a 13 lb rad cap instead of the 4 lb on the 990. I have not tried this installation but anything can be done with time and patience.
Is it dear to have yours recored?
