Case 411b
Rich in Ut
11-14-2005 14:59:40
I just picked upa 411b with a loader, It seems very straight. It is missing only the carburator. I thought the 411b had a common engine with a few other models (4 cyl gas)can anyone verify that. If so my hunt for a carb should be a little less painful. It seems like they were only built in 58 & 59, but hopefully the engine was more common. Any insight would be greatly and sincerely apreciated. I am out west in UTAH. Thanks again.
Rahlo
11-20-2005 21:04:03
 Re: Case 411b in reply to Rich in Ut, 11-14-2005 14:59:40
Contact Don Livingston at rustyacres and tell him your problem. I bought a carb from him and it was everything he said it would be.
Joe (Wa)
11-14-2005 17:24:23
411B has the 148 cid gas engine. Factory gas carb was Marvel Schebler TSX-749 or Zenith 62AJ10-outline #12329.
Joe
charley hellickson
11-14-2005 17:23:02
400B tractor is the same as 300B.only diffirence is 400B is C-O-M and 300B is standard clutch and drive.300,300B and 400B are the same engine.
FiremanJohn
11-14-2005 17:22:23
It is a G148 gas engine. Quite common. The carb is a Marvel Schleber or some spelling similar to that. Good luck. There are quite a few of us with those tractors on this board so we can hopefully help.
martin in DE
11-14-2005 18:48:59
 Re: Case 411b in reply to FiremanJohn, 11-14-2005 17:22:23
the engine is a 148 CID.but the block,intake manifold and carb are different than a 300 or 300B regards martin
Rich in Ut
11-14-2005 21:39:42
 Re: Case 411b in reply to martin in DE, 11-14-2005 18:48:59
Thanks a ton all I really apreciate the input, I think this is gonna be a great little tractor. I got it for nearly a song, I am tickled to have it and anxious to bring life back into her engine/ Thanks again and all have a fantastic day. Rich
