International 424 hydraulic fluid leak into engine
Ronnie Williams
11-14-2005 12:27:59
HELP. I have hydraulic fluid somehow getting into my engine oil. This is a gas 424. It fills the oil pan up over a period of about two months, about 20 hours of operation. When rpm get about mid range oil is forced out the air vent on top of motor.
Bill Sickle
11-14-2005 19:08:37
 Re: International 424 hydraulic fluid leak into en in reply to Ronnie Williamson, 11-14-2005 12:27:59
Ronnie,
This is somewhat common. The " O " ring seal
between the hydraulic pump and the timing gear
housing is leaking. Just be careful not to turn
the pump gear during disassembly or reassembly
or you'll have to retime the ignition.
Antique Puller
