lift quits when warm
jms
11-14-2005 08:51:15
i have a 630 case i just replaced the seals in the rockshaft they were bad.but the lift stops working when it warms up i though the seals would fix this but it didnt.could it be the control valve, or the hydraulic pump. what do i check next
Roger (Mi)
11-16-2005 05:46:37
 Re: pressure check in reply to jms, 11-14-2005 08:51:15
Hopefully, you have a remote control valve. With the engine running, you could move the remote valve (without anything attached) back and forth. There should be a squeal or the engine should slow down slightly. If it doesn't, there is something wrong with the hydraulic relief or the hydraulic pump. If you could hook up a pressure gauge to one of the remotes, it should have about 1500 PSI. The hydraulic relief and the pump are under the cover where the control valves are located.
