case La and case 600
mta puller
11-13-2005 16:54:40
Can someone tell me what the big difference is between a case 1952 case LA and a 1957 case 600 and a case 900, thinking of doing one to pull with, how about engine parts and interchanging things, they seem a little odd, and what cid are these 3 tractors, thanks
charley hellickson
11-16-2005 21:11:54
 Re: case La and case 600 in reply to mta puller, 11-13-2005 16:54:40
LA is 401 cubic inches.500,600,900 are 366 cubic inches.930 disiel is 401 cubic inches.
xiafarmkid
11-15-2005 22:10:13
There are guys pulling Case 600's that have gotten better then 1000 cubic inches out of the factory block. I believe stock was about 381. Not certain though. One I saw pull was putting out over 230 horsepower. Show me an LA that will do that... Those two extra cylinders make a huge difference. The 600 came as a factory LP tractor as well as a diesel. Take an LP tractor, throw on a diesel fuel tank, convert her to gas and you'll be taking home alot of trophies. They one tough pulling machine.
Jim FL
11-15-2005 15:39:12
I pull a 900 LP converted to gasoline. Last weekend I pulled in two 10,500 classes; one was a farm stock 1965 and older. The 930 came in first, 4010 JD second and 900 was third. In the antique class which allows cut tires and hanging weights, the 900 first, 600 IH second and R JD third. There were at least 10 - 12 per class. The rest of the tractors were 830 - 820- 80 and R's.
shoe
11-13-2005 18:53:13
If you're going to pull with one of the three, the
LA is the best of the three. I grew up on a LA,
what a puller it is. A couple of guys in our pulling club have a 500 and a 900, they are too high geared
in first gear and power out on the sled too quick.
A guy from another area came to one of our pulls last summer with a LA, and beat everyone in it's class. 500, 900, JD 820, wd9 international, and a couple outhers I can't remember. the LA stock is
401 CI's and a 4 cylinder gas. the 500 and 600 are diesel, don't know the CI's of the 600 but the 500 is less than the LA and higher geared, and doesn't have the lugging power of the LA. My dad
put bigger sleeves and pistons in ours, years ago
and I think it made it a 438CID. what a puller it
was and got the traction to the ground. I would go
with the LA, Just educated experience.
Good luck and have fun with what ever you decide.
Steve-MN
11-13-2005 18:30:27
Also, LA is a 404 CID. Runs at 1100 RPM.
Steve
Tom Railsback
11-13-2005 17:27:19
The main difference between the LA and the others is LA = gas and the others are diesels. AS far as engines in the diesels, they are essentially the same.
The 500 has a 4 speed transmission and the 600 and 900 have 6 speeds.
dctom
11-13-2005 17:00:43
case LA only 4 cylinders 600 and 900 six ,LA only about 60 hp others should be 85 stock
55 50
11-14-2005 09:17:17
 Re: case La and case 600 in reply to dctom, 11-13-2005 17:00:43
A stock LA is more like 40 HP instead of 60.
steveormary
11-14-2005 09:53:35
 Re: case La and case 600 in reply to 55 50, 11-14-2005 09:17:17
55 50
My book shows Case LA gas at 58.53 belt hp. and 51.68 dbhp.
Case 500 diesel 6cyl.@1350rpm 63.8 and 56.32 hp.
55 50
11-14-2005 17:27:24
 Re: case La and case 600 in reply to steveormary, 11-14-2005 09:53:35
I stand corrected. I just looked in my Neb test book by Lester Larson and that shows exactly your numbers. Is that the same book you used?
I was going by what I observed while growing up. An uncle had a Case LA and traded it for a JD R (same book shows the R at 43 HP) which was a step DOWN in power, but he must have done that for the fuel economy. Without thinking of those things as a kid, I assumed he was stepping UP in power.
55 50
11-14-2005 17:27:08
steveormary
11-14-2005 20:14:27
 Re: case La and case 600 in reply to 55 50, 11-14-2005 17:27:08
55 50
This is from a book by Lester Larsen titled Farm Tractors 1950-1975. The model year was 52-53. Some of the earlier models were probably not that powerful and your post might cover them.
steve
mta puller
11-13-2005 19:08:53
great input, thanks to all, are the parts available or is alot of retrofitting on engines needed, ie, sleeves, pistons, what heads are best and general cost of case parts, thanks
mike's600
11-15-2005 04:11:16
 Re: case La and case 600 in reply to mta puller, 11-13-2005 19:08:53
The case 600, or 900 is your best pick for pulling!You can build as big as you want, (time and money. Ihave several tractors to pick from if you are interested.
