CASE SC
Cory @ Lander
11-13-2005 16:05:20
I purchased a 1947 Case SC last weekend and know nothing about it. I changed the plugs and literally cleaned out the fuel line of webs. I tried to crank start it and almost got it started but then my lower back gave on the up/down swing of the crank. So, it has a starter, a couple of battery cables, one connected to a pushbutton type switch and the other assume would connect to the starter. If I purchase a battery, am I dreaming, or is that all I need.
Much appreciate any help or advice. Thank You
Cory
JGarner
11-14-2005 08:18:07
 Re: CASE SC in reply to Cory @ Lander, 11-13-2005 16:05:20
Take a look and see if it has a generator or been coverted to 12 volt with altenator. If its still a generator then make sure you buy a 6 volt battery.
jal-SD
11-14-2005 07:50:07
Should do it, be sure the terminals are clean. (My $0.02 worth. jal-SD)
