adding pto
mike onion
11-13-2005 16:00:52
i just purchased a case 580bck loader and would like to add pto ser number is 8731419 iam vary resource full but would like to start out well informed if any one has inf please advise thanks mike o
Butch/OH
11-13-2005 18:07:10
 Re: adding pto in reply to mike onion, 11-13-2005 16:00:52
Is your tractor a manual shuttle or a power shuttle? If it is a power shuttle you will have to remove the seat,floorboard,and transmission cover over the differential. You need to look at the shaft coming through the 4 speed trans. and see if it is hollow. There might be a freeze plug in the back to take out. A shaft needs to go clear up to the back of the torque converter if it is a power shuttle. There also needs to be a seal retainer at the back of the 4 speed to hold a seal and seal off the shaft from the differential compartment.
mike onion
11-13-2005 18:53:13
 Re: adding pto in reply to Butch/OH, 11-13-2005 18:07:10
the tractor is manual shuttle
