Bolts vs Studs
Paul f
11-13-2005 07:02:27
The drawbar support assembly on my Vac is mounted with a bolt on one side and a NF/NC stud on the other. According to parts manual the stud is correct. I notice that the PTO carrier plate on my DC also uses studs. It got me thinking (since I have bolts in stock but not studs)what was the advantage of a stud over a bolt???
In normal use would I ever see a difference if I used bolts in lieu of studs??
Walt Davies
11-13-2005 10:22:04
 Re: Bolts vs Studs in reply to Paul f, 11-13-2005 07:02:27
Yes the Studs use an NC thread to hold in the softer Cast Iron or Steel and the NF threads to get a better torgue on the item being held. Walt
