oil problem near valves on Case D
Henk M
11-12-2005 14:13:26
I just rebuild the head and fired the unit without the valve cover and don't see any oil coming out of the valvelifter arms is this normal, the pump does work but after running the enige for a few minutes the top of the head still had no oil on it if you have any comments on it please let me know.
Glenn FitzGerald
11-12-2005 16:23:12
 Re: oil problem near valves on Case D in reply to Henk M, 11-12-2005 14:13:26
Assuming you have adequate oil pressure, you likely have the oil journals of the rocker arm assembly upside down. Take the rocker assembly off, push a rocker arm aside& make sure the oil journal is on the bottom. If it is on or near the top it will seat and prevent oil from "leaking" out. Glenn F.
Glenn F.
11-12-2005 18:56:37
 Re: oil problem near valves on Case D in reply to Glenn FitzGerald, 11-12-2005 16:23:12
I got that backwards. Oil journal needs to be on the top. Glenn F.
return message.
11-13-2005 08:41:39
 Re: oil problem near valves on Case D in reply to Glenn F., 11-12-2005 18:56:37
Thanks for your help.They were facing the wrong way.Does the oil come direct from the pump or does it come from the filter I don't have any oil coming up but the oil filter line has been disconnected and I do have pressure on the gauge.
response to L Lamp
11-13-2005 13:56:38
 Re: oil problem near valves on Case D in reply to return message., 11-13-2005 08:41:39
I have removed the 3/8" line. Turning over the engine and shining a flashlight in the spot where the line came out of no oil comes out of it.
I think that the line is clogged I bought this tractor seized one piston hole was full of water and no maintenance was done to it in the past 40 years.
L.Lamp
11-14-2005 21:12:52
 Re: oil problem near valves on Case D in reply to response to L Lamp, 11-13-2005 13:56:38
From the illistration in the service manual for D engines, the passage in the block that supplies oil for the valve train comes from the middle cam bearing. There could be a clog in this passage way. The pipe to the rocker arms is installed in this passage way. FYI.
L.Lamp
11-13-2005 13:35:10
There is a fitting that goes between the two rocker shafts. It has a hole facing straight down with the edges of the opening parallel to the head surface. There should have been a pipe sticking up from the center of the block that goes through a hole in the head that just fits inside the fitting on the rocker shaft. If the pipe is not there, someone may have pulled it out and plugged the hole in the block. Oil for the rockers must come through this pipe or the rockers get no oil!! You may need to unplug this hole and install a new pipe. The pipe is about 3/8" in dia.
