All fuel manifold
Casenut
11-12-2005 07:13:21
I am restoring a 1929 C and have an old style all fuel manifold that is in great condition with the short straight pipe. I am wondering if anyone has tried to block off the exhaust from going into the bottom chamber and what you used to block it off. I will only be using this tractor for show. I would like to drill a hole in the bottom chamber to drain any moisture. Thanks for your help.
WALTER T.
11-12-2005 17:11:07
 Re: All fuel manifold in reply to Casenut, 11-12-2005 07:13:21
I WOULD HAVE TO AGREE WITH DON. I DID THE SAME THING TO MINE.
Casenut
11-12-2005 18:20:24
 Re: All fuel manifold in reply to WALTER T., 11-12-2005 17:11:07
Walter, how thick of metal did you use and how did you seal it?
Don Livingston
11-12-2005 14:03:29
Yes a block off plate can be made. Stainless steel would work [or whatever you may have]. I have seen some manifolds with a a small drain hole in them , but they fill up with carbon.
Don L.
