580 CK
Case
11-11-2005 19:26:31
I am trying to find out what is the engine rotation direction when sitting on the seat facing forward? The tractor I am working on is a 580 CK backhoe with the 188D engine. I bought it with the engine supposedly locked up. Today I dropped the oil pan and was able to turn the engine with a screwdriver in the flywheel. Just wanted to check for the correct direction. Thanks for the help. Case
Case
11-14-2005 05:25:46
 Re: 580 CK in reply to Case, 11-11-2005 19:26:31
Thanks for the help! I was turning it in the wrong direction. Next chance I get I will turn it the other direction and see if I find any hang-ups. Another question, what is the torque specs on the rod and main caps of the 188D engine. Thanks, Case
Roger (Mi)
11-13-2005 04:54:44
 Re: 580 CK rotation in reply to Case, 11-11-2005 19:26:31
If facing the crank pulley (grill), it's CW (Clock Wise)
If facing the flywheel (driver's seat) it's CCW (Counter Clock Wise)
streaker
11-12-2005 08:27:32
Now, George and Walter have each posted opposite rotations! Is there a different model engine or what?
BKahler
11-12-2005 16:01:41
 Re: 580 CK in reply to streaker, 11-12-2005 08:27:32
I'm in agreement with George. When looking at the front of the motor (in front of the tractor) it rotates in a CW direction. I asked this same question of George many months ago when I was rebuilding mine and it was CW then and its CW now!
Brad
george md
11-12-2005 12:10:31
There are very few left hand rotation engines , some
in marine applications and some in rear engine buses . almost all other engines are right hand rotation ( clockwise viewed from the front as in the fan end ).
george
WALTER T.
11-11-2005 20:44:43
THE DIRECTION IS CLOCK WISE IF YOU WERE ON SEAT.
george md
11-11-2005 21:03:25
 Re: 580 CK in reply to WALTER T., 11-11-2005 20:44:43
Direction is clockwise if looking at the front of tractor. ( standing in front and looking at tractor.)
george
BKahler
11-12-2005 04:53:05
 Re: 580 CK in reply to george md, 11-11-2005 21:03:25
Hi George,
Hadn't see you post in a while. Just wanted to let you know my 188 runs great now, starts first time every time!! Thanks for all your help, and wisdom.
Brad
