vac hydraulic pump
cleatusj
11-11-2005 16:29:32
Will a "47 vac hydraulic pump fit the trougktube and work on a "50 vac. I would like to do this to run the eagle lift so I could use the third lever of my present valves to run a grapple on the loader.
WALTER T.
11-11-2005 20:48:53
 Re: vac hydraulic pump in reply to cleatusj, 11-11-2005 16:29:32
THE PUMP FROM A 600 CASE COMBINE 188 OR 201 ENGINE WILL FIT ON THE ENGINE OF 124, 148, 154, 188, 201 I USED IT TO REPLACE THE VAC PUMP ON ENGINE. JUNK YARD'S CHARGE 75.00 WITH 30 DAY WARRENTY. OR USE THE LIVE PUMP YOU HAVE ON THE ENGINE.
F-I-T
11-11-2005 16:49:10
Cleatus:
I think that older pump is what they call the "High-pressure" (low volume) pump. The pressures are not the same as those at the engine driven "Eagle Hitch" pump, and the volume is pretty low with that piston pump. It's also not live power.
You could just tap into your pressure and return lines and use a two or three spool open center valve and have all the outlets you need, and still have the Eagle hitch available.
Frank
