Case-O-Matic 730
Rick Whitley
11-10-2005 17:42:55
I have a Case 730 with Case-O-Matic drive that I pull in the antique class. The tansmission seems a little weak. I plan to work on the engine to increase the horsepower but am concerned about the Case-O-Matic holding up the increased horsepower. Is there anything that I can do to the transmission to make it stronger?
charles hess
11-11-2005 09:41:30
 Re: Case-O-Matic 730 in reply to Rick Whitley, 11-10-2005 17:42:55
Probably could set up clutch pressure if you think they are slipping.
mike's600
11-10-2005 18:40:35
Check the filters for the tranmission, should handle the power
