Rear Rim
BALDEAGLE
11-10-2005 16:35:27
Can anyone tell me where I can buy a new or used rim to fit a Case 500 Deisel? Tire size is 18.4 X 30, on a 16" rim. THANKS!!!!!
raiken
11-13-2005 04:13:03
 Re: Rear Rim in reply to BALDEAGLE, 11-10-2005 16:35:27
I have a two 16 by 30 old{new stock}. These are drop center T RAIL DULES. If you want like new rims and have the time and energy, you can cut off the spacer and the T rail, grind smooth, tutch up paint, weld in a slip block,you will be ready for new tires. I did this for my MM UTS.
Engineer20
11-12-2005 15:22:45
Baldeagle,
I"m looking for the same rims. I"m going to call Heywheel (heywheel.com) and see what they say. I also have a wheel shop in Omaha that I"m going to check with also. You could also try any of the tractor salvage yards in your area. If I find out any info I"ll let you know, do the same for me.
