1030 desiel will not start, sit for couple years
ted wil.
11-09-2005 15:25:05
case 1030 desiel will not start, have fuel to pump ok. Wonder if fuel shutoff inside pump is gummed up. been sitting a few years. anybody know how shut off works?
CNESLER
11-10-2005 04:43:35
 Re: 1030 desiel will not start, sit for couple yea in reply to ted wil., 11-09-2005 15:25:05
I had a 930 that had set up for four years and
would not start. took everthing apart and found
mud dobbers nests in both the inlet air breather
and exhaust manifold.cleaned and pull started tractor and it has run fine ever since.
Good Luck
CNESLER
c hess
11-09-2005 16:02:30
Due easy stuff first . Make sure clear fuel is coming out of top of all filters at air bleed on each filter. Than you could crack return line on pump to release any air there buy pumping hand pump. If you dont get any white smoke out of exaust after reasonable cranking you might have to remove cap on front of ixection pump an make sure rack is free. Should move back an forth by hand. Put cap back on an try again to start. You could also crack lines at inxectors an see if any fuel comes out. Also some one else on forum had to remove hand pump an clean as it was fu. of dirt. You should feel resistance when using hand pump.
Old Rusty
11-09-2005 15:58:03
More than likley the rack is stuck in the closed position. Remove the cover on the front of the pump ( round cap. takes a 3/4 wrench ) you should see a alen head screw. Open throttle up to full. pull and push rack in and out while spraying some penatrating on on it. When it is free enough to move with the throtle it will probibly run OK.
chess
11-09-2005 16:12:34
 Re: 1030 desiel will not start, sit for couple yea in reply to Old Rusty, 11-09-2005 15:58:03
Rusty i totally agree with your advice on 1030 starting. Wehad5 of those pumps over years an they are bullet prof!!! I got question for you. How many washers can i take off of830 pump rack ?? Thatwill give more power wont it for tractor pulls?
Ol Chief
11-10-2005 01:08:04
 Re: 1030 desiel will not start, sit for couple yea in reply to chess, 11-09-2005 16:12:34
Hey, ted wil; If my memory serves me correctly you can adjust power output by moving an adjustment screw located at the back of the pump.This can be identified by looking for a stud looking 8-32 thread with a hole thru which a wire is attached and a lead seal is secured at the factory.If this has not been previously removed you will need to cut this off to adjust.Be careful.
