VAC cylinder head
Case
11-08-2005 16:33:36
Getting ready to put the head back on the 49 vac and am needing to know were washers used and were they like a grade 4 or some type of soft metal washer, or no washers at all? Also what was the torque sequence on the vac. My manual says that it is similiar to the S series shown in the manual. Thanks for the help. Case
Joe (Wa)
11-08-2005 19:46:14
 Re: VAC cylinder head in reply to Case, 11-08-2005 16:33:36
Case parts manual lists washers (14) used on studs after engine serial #VAB12908. 1949 probably will have a later eng serial nr starting with VAC or A47. No grade is listed. Note that the washer's OD has to be less than you normally find on a 1/2" washer. I have been using grade 2 finishing washers.
Go to the link and click on page G2 F6 for torque sequence.
Joe
