Hydraulic Hose for 580CK loader/backhoe
John Gleaves
11-08-2005 06:49:56
I blew one of my longer hydraulic hoses (64" hose) on my Case 580CK Backhoe arm. My question is, can I get away with getting a new one at Tractor Supply or do I need to go to a hose & gasket store. Tractor supply is much, much cheaper.
Tractor Supply"s website gave this description of their different hoses:
1/2" 2-Wire - 3500 PSI working pressure. Rigid male ends - 1/2" NPT. 3/8" 2-Wire - 4000 PSI working pressure. Rigid male ends - 3/8" NPT. 3/8" 2-Wire - 4000 PSI working pressure. Rigid male ends - 3/8" NPT.
Please let me know what size I need (i.e. 3/8 or 1/2) and what PSI I need to get.
Thanks for the help!
joe francano
11-08-2005 19:15:30
 Re: Hydraulic Hose for 580CK loader/backhoe in reply to John Gleaves, 11-08-2005 06:49:56
How can I tell what sizes are the threads for replacing hoses? I can measure the outside of the nuts, but I am not sure if that is the size of the hoses to buy.
Thanks.
Roger (Mi)
11-09-2005 06:46:23
 Re: Hydraulic Hose thread end size in reply to joe francano, 11-08-2005 19:15:30
As mentioned before, 5/8" hoses are the standard for Case L/B's. The easiest way to assure the proper hose ends is to take the old hose with you to the place where hydraulic hoses are made up. Case does NOT use pipe thread ends. If the hydraulic hose dealer does not have the proper ends, he can get them. Southwestern Supply in St. Joseph, Michigan can make up any hose (with the correct ends) for any Case L/B.
joe francano
11-09-2005 08:23:03
 Re: Hydraulic Hose thread end size in reply to Roger (Mi), 11-09-2005 06:46:23
I can buy hoses very cheap from a company called mc master carr. The problem is they are a catalog company and I would need to know the sizes to order.
Can I just measure the threads with a micrometer?
Roger (Mi)
11-09-2005 15:25:47
 Re: Hydraulic Hose thread end size in reply to joe francano, 11-09-2005 08:23:03
Joe,
Call that company, and talk to someone who knows. Certainly, the flare fittings and ends used by Case should be common knowledge if they have a fair sized business. Yes, use a caliper or micrometer to assure yourself that they are going to send the correct ends. Good idea. Good luck.
Roger (Mi)
11-08-2005 15:51:37
 Re: Hydraulic Hose size for 580CK is 5/8 in reply to John Gleaves, 11-08-2005 06:49:56
The correct hose size for Case backhoes is 5/8". The 1/2" hose is too small, and the 3/4" hose size is too big to get through some of the openings. Since the working pressure for Case backhoes is 2000 psi, hoses that withstand 3000 psi work fine.
Erik KY
11-08-2005 09:41:59
I have an old 530CK and most of my hoses look like they are 3/4". Tractor supply sells a 3/4 inch hose, but its only 24 inches long (it was about $13). A 1/2" hose would work (with the right adapters on the ends) but your flow would be restricted so the boom may not move as quickly, though the force would be the same.
I'm not sure what your pressure relief is set at but I would guess a 3000 psi hose would be good enough.
old
11-08-2005 08:17:22
A hyds hose is pretty much a hyds hose. All have to meet a standard and some are cheaper then others. As long as the PSI rating is the same or higher go with the cheap one.
wayne2
11-08-2005 07:15:12
Use what works!! If cheap buy 2, I've occasionally used bailing wire to get back on track. LOL W
John Gleaves
11-08-2005 13:48:26
 Re: Hydraulic Hose for 580CK loader/backhoe in reply to wayne2, 11-08-2005 07:15:12
I appreciate the help. I will give the cheap one a shot and see if it works, if not I'm back in the same situation.
