Oil leak behind belt pulley--SC '49
Case kernel
11-08-2005 02:35:56
Trying to address some of the leaks. Behind the belt pulley is a flange with three bolts. The leak is between the flange and the housing. Is there a gasket there that can be replaced, or are they just shims. Can the bolts be loosened and goop be applied to shims to stop the leak without the whole pulley removal, etc.? It does not appear to be leaking around the seal of the belt pulley shaft.
