front end VAC
scott vaughan
11-06-2005 11:51:26
Going down the road the front end vibrates violently. Shakes the steering wheel and all. Can ya ll help. Thanks.
JeffLTN
11-09-2005 07:16:07
 Re: front end VAC in reply to scott vaughan, 11-06-2005 11:51:26
Scott, my dad's VAC did the same thing for years. We tried tightening the tie rod ends, tightening the set screw to take up some of the end play in the steering gear box and finally resigned ourselves to driving it very slowly and trying to stay to the right of the crown on paved roads. The pot holes on the dirt road would wreak havoc with that thing.
Finally last summer when I was taking some kids on a hay ride my cousin spotted the nose wheel pillar coming lose from the frame casting. Two of the four bolts broke off when I tried to tighten them and had to be drilled out. Check out these blolts. Dad's front end was really loose and the problem is hard to see from the driver's seat. Replacing these four bolts made it drive like new.
I know the VAC is not the best steering/handling tractor but we finally made Dad's manageable.
scott vaughan
11-10-2005 20:14:53
 Re: front end VAC in reply to JeffLTN , 11-09-2005 07:16:07
Thank you very much. I have not inspected that end of the steering yet.
caae poor in pa
11-08-2005 15:50:18
#1 find a smooth road #2 tighten your front bearings # 3 take jack lalane arm exercises
