tires on my vac
hdlg
11-06-2005 06:07:33
I changed the tires on my vac. I took the rims and all off my vc and put them on my vac. The vc had been sitting for several years and they are also loaded with calcium. Now when I take my vac for a ride on the road the tires seem to be wobbling almost like it was not balanced. (like a car tire) I tightened them evenly and the clamps on the axle look even. could the calcium lump up in one spot to make this happen? I am not worried about the tires falling off, I am worried about ruining the rear end with the tires wobbling. Please Help
old
11-06-2005 06:40:18
 Re: tires on my vac in reply to hdlg, 11-06-2005 06:07:33
Well if they sat a long time then there probably out of round. I've never heard of filled tires getting lumped up and casueing problems. Jack the tractor up and turn each tire makeing sure they are mounted true and also watch for high spots on the tires. Use blocks beside the tires to check for turnness and watch under the tires and make sure the tire stays the same distance form the ground.
