311 roundnose
C.D. Zook
11-05-2005 05:57:39
I have a roundnose 311 and the upper section of the roundnose, which contains the outer circle that contains the case emblem is broke off. Would anyone have a straight replacement with the circle intact for sale? Thank You, C.D. Zook
wayne2
11-08-2005 07:21:24
 Re: 311 roundnose in reply to C.D. Zook, 11-05-2005 05:57:39
I got that piece over on coast-no emblen-dented, replaced my grill with expanded steel(black) I use my 300 hard!!(love er) W
John Nobody
11-06-2005 03:54:37
You might try Roger Hornbaker at 301-223-9005. He does some dealing with 300-350 hood parts.
Case300
11-05-2005 17:14:40
C.D. I just made a a partial circle for one of my customers out of a piece of 3/4"W by 3/8" thick piece of aluminum and he had some one he knew weld it on and said it worked very well. You would need to cut the partial circle down to match up with your frame to make it complete. Well worth the effort though. Also Don Livingston mention he had that piece of a frame and you might check with him to see if it would fit on to your frame. Roger
