800 diesel
Jebby
11-05-2005 04:43:58
How can I fix my 800 diesel to keep it from leaking oil out of the tube hanging down from the Bosch in-line pump? I have an 830 that has this line hooked into the side of the block, can I do that to the 800? Seems as though every time we load tractor or drive it on concrete it is drippin black liquid.
roger tremaine
11-09-2005 17:57:37
 Re: 800 diesel in reply to Jebby, 11-05-2005 04:43:58
Pump would have to be updated to be run with engine lube oil-plungers and barrels and supply pump would have to be replaced, pricey. install a used 830 pump should be cheaper.
