how do I get more HP out of my VAC?
plantman
11-04-2005 07:25:10
Any Ideas? I need to turn and put new bearings in the bottom end, so it is all apart.
Augie
11-04-2005 09:09:13
 Re: how do I get more HP out of my VAC? in reply to plantman, 11-04-2005 07:25:10
Get in touch with Don L. He has a piston/sleeve kit that will take it from 124cid to 139cid, and needs no additional machine shop work to fit. Buy a G159 cam or send your old cam to a cam grinder that knows what to do with a tractor cam. You can take up to .125" off the cylinder head without getting in trouble there. Open the main jet in the carb one or two letter drill sizes. If it has a Zenith carb - throw in trash - replace with Marvel-Schebler. If it has the flyball governor toss three of the balls. Make sure governor linkage is in good shape - nothing loose or binding. Replace spring on governor linkage - .082" wire size is about right. Clean up intake and exhaust ports - match to gaskets. Do the same to intake/exhaust manifold.
That will get you up around 35hp. If that's not enough then you need to spend $$$...
Ron LeVine
11-04-2005 07:57:01
Greetings,
Although I am not much of an expert on tractors in general, I have made lots of horsepower in automotive applications and tend to think that there is a certain amount of stuff that will cross over from there into the tractor scene.
1) Shave the head(increase the compression)
2) Port and Polish the head.
3) Increase the size of the carb so as to allow for a faster rate of RPMs (horsepower is a mathematical function that has torque and RPMs in it).
4) Increase the lift and duration on the cam.
5) Balance the engine.(this won't nessecarily give more HP but it will help the engine to not lose the HP it is already making by beating itself to pieces.
Just my .02$ though I could very well be wrong.
