Case 2096
G. Murry
11-03-2005 10:56:55
I am currently looking at a Case 2096 at an auction this weekend. I am wondering about their reliability, any problems starting, and I am a little leary of an all electronic dash. What does front wheel assist refer too and how can it be identified on the tractor? Any help would be greatly appreciated.
Triplerange
11-04-2005 09:00:27
 Re: Case 2096 in reply to G. Murry, 11-03-2005 10:56:55
We have a 2094 which is the same thing only a year or two older and has the case 504 engine instead of the cummins 5.9L. Both engines are very good. The electronic dash isnt that big a deal. Frankly I think the 2094 is one of the easiest tractors to work on. The one thing that bothers me is that the lights have a relayed switch on it so problems with lights are hard to troubleshoot sometimes. But overall its a good tractor.
John Saeli
11-03-2005 18:14:58
We've owned a 2096 for 8 years. Great Tractor!! Economical engine with unbelievable Torque. Trouble-free tractor..
kcrw79
11-03-2005 11:52:30
I can't comment directly on the 2096. But I do have experience with a 2294 (Size bigger and one series older). We have a couple '94 series with electronic dashes and haven't had any issues. YMMV
As far as "front wheel assist" is concerned, it is a great feature. It will be readily obvious if the tractor is so equipped. The front wheels will have lugged tires similar to a rear tractor tire. They will be larger than a "normal" front tire, but not nearly as large as the rear wheels. This is also known as MFWD. The 2294 I mentioned is equipped with it. Although it's the smallest tractor on the farm, it's the one we go get when it's real muddy, icy, etc.
On the 94 series, the FWD is a part time system, which means you only run it when you need it. I would assume the '96 tractors are the same way.
