Trouble shooting power steering
RL-WI
11-02-2005 21:08:25
I did an out of frame overhaul on a 480C 188 diesel engine. After about two hours of running, the power steering slowly stopped. There�s a little power steering when cold, but it as the engine warms up, it quits. Than I can�t turn the steering wheel at all on less I raise the front wheels off the ground. With the engine warm, I can�t turn the steering wheel at all. It gave out a little at a time and not all at once. After the overhaul, I refilled the fluid, topped it off when it started and topped it off again after bleeding out the air. I tried replaceing the filter but with no affect. How do I trouble-shoot the problem??? RL-WI
BKahler
11-04-2005 04:22:42
 Re: Trouble shooting power steering in reply to RL-WI, 11-02-2005 21:08:25
RL,
I can't necessarily help you with your problem because I'm pretty much in the same boat you are. I just finished an engine rebuild. As part of that rebuild I took the power steering pump apart, replace the seal and some o-rings and put it back together. When I first got the engine running with the wheels off the ground I could turn the wheels both directions (after bleeding that is). Now its like wrestling a bear trying to get the tractor to turn. I've hardly driven it but it got worse the more I drove it.
From what I can find in the archives it kinda sounds like the two steering cylinders might be leaking internally. I'm going to rebuild the two steering cylinders first and see if that corrects the problem. Unfortunately I only have one seal kit so can only do one over the weekend. But if I get it done I'll let you know what I find out.
If you find a resolution let me know!
Brad
RL-WI
11-04-2005 17:56:14
 Re: Trouble shooting power steering in reply to BKahler, 11-04-2005 04:22:42
Brad
Guess we�re both in the same boat. The tractor�s unusable like it is. Some where in the archives, I also recall the some thing about the two leaky steering cylinders. There must be a way to trouble shoot the problem or by eliminating other parts, pump, valves etc. Please let me know if have any luck. I�ll do the same. My oldest friend in world just had a major heat attack; it�ll be a while before I get back to work on it. Good luck, I�ll look you later. RL-WI
