case 2590 lock up
T BOWEN
11-02-2005 16:53:13
i have a problem with a 2590 that locks up when the clutch is applied when slowing down with cold oil and sometimes when pulling you can start to feel it bind up. i know of another 2590 and a 2390 doing similar problems. i was wondering if anyone knew a fix and if so your help would be much appreciated. THANKS,TOM
turbo
11-02-2005 19:11:52
 Re: case 2590 lock up in reply to T BOWEN, 11-02-2005 16:53:13
Does it kill the engine when you depress the clutch pedal? Check and see if C-3 spool is sticking in the control valve.
If it slides the rear wheels when depressing the clutch pedal, C-3 retard needs to be turned out a little.
case trader
11-03-2005 16:19:41
 Re: case 2590 lock up in reply to turbo, 11-02-2005 19:11:52
you need to polish the spools in the control body on right side of tractor you can look in your book to help locate,take one out at a time i chuck it in a cordless drill use real fine emery an replace should cure the problem, seems common when cold.
