Shiifting problem--SC
Casekernel
11-02-2005 11:49:32
Took my shift lever out for cleaning and painting and put it back. Now it won't move up and down--just from one side to the other (I think from 4th to neutral to 3rd gear as the shift lever is in the higher position). What did I do wrong? I have had the tractor apart (idle for a year or so, so haven't driven it--cleaning and painting), but know that I should be able to shift into all gears when standing idle. Will be starting the tractor up on Friday or Saturday--so any help before then would be appreciated.
dctom
11-02-2005 12:25:25
 Re: Shiifting problem--SC in reply to Casekernel, 11-02-2005 11:49:32
pull the shift lever out again and make sure it is in the pocket it belongs in sounds like it is not where it belongs tom
L.Lamp
11-02-2005 18:22:49
 Re: Shiifting problem--SC in reply to dctom, 11-02-2005 12:25:25
Remove the shift lever and look inside where the bottom of the shift lever goes. There are three shifting rails with a groove in the center to accept the shift lever. They must all be lined up in the center from top to bottom. If not, the only gears you can shift are the grooves the lever can fit into when the lever is replaced. All the rails must be in the center before you can choose which side you want to select from. Use a large screw driver to move the out of line rail or rails to the center. I hope this helps!
Case Kernel
11-03-2005 14:14:48
 Re: Shiifting problem--SC in reply to L.Lamp, 11-02-2005 18:22:49
Did what you guys said and it worked. Thanks!
