Case VC with starter problems (update)
Jim on the left
10-25-1999 23:49:09
I received my manuals for my 1941 VC tractor and discovered that the starter cable and the negative battery cable were reversed (the negative battery cable was connected to the left starter button terminal and the starter cable was connected to the right starter button terminal). I reversed the cables as instructed in the manuals and I was able to start my tractor without push starting! And yes, the positive battery cable does go to ground. I also had to reverse the ammeter connection (because the connection is supposed to be on the side of the starter button connection that the negative battery cable is connected to.
I'm still learning and hope to discuss the next issue I come across while trying to restore this tractor. Thanks again for your comments C. Amick's ...
