Case engine
Tony In Ohio
11-01-2005 12:59:12
I have a Case engine that is out of a 600 combine (I think). The S/N is 2041342 (no model number on plate). Can anyone tell me what Case tractors this will fit. It looks the same as the one in my 430 tractor, but the short block is 20.25 inches long and the one in my tractor is only 19.0 inches long.
Tony in Ohio
11-02-2005 05:11:07
 Re: Case engine in reply to Tony In Ohio, 11-01-2005 12:59:12
Thanks to everyone for your comments.
So is the concensus that it is probably a model 188? Does the 188 have a short block length of 20.25 inches? or is it the 19 inch short block?
Thanks,
Tony
Nedd
11-01-2005 14:13:55
The engine in the combine is a case 159 and the one in the 430 is probably a 148. The bolt holes I believe are the same but to interchange different tinwork would have to be done.
John Saeli
11-01-2005 16:52:13
 Re: Case engine in reply to Nedd, 11-01-2005 14:13:55
Hey Nedd: I could be wrong, but didn't CASE use the 188 in the 600? The 201 was used in the 660. Both the 201 & 188 are the same length. I believe the 148 & 159 are also the same length, both shorter than the 188 & 201.
Nedd
11-02-2005 06:00:03
 Re: Case engine in reply to John Saeli, 11-01-2005 16:52:13
Your right. spoke too soon.
discount dave
11-01-2005 17:31:19
My 600 combine has a 188 on it. Dave
WALTER T.
11-01-2005 19:19:51
 Re: Case engine in reply to discount dave, 11-01-2005 17:31:19
THE ENGINE YOU SPEEK OF IS ABLE TO FIT IN A CASE 630 FOR SHURE AND 580CK MODEL'S
