Vac eagle hitch problems
S.Gross
11-01-2005 07:01:03
I have a steady flow of oil coming out the vent tube when you try to lift the arms.Also a lot of oil coming out of the control side of the rock shaft.My tractor is a 1950 and I've been told that the piston is leaking,how do I fix it?Will I just be able to take the allen bolts off the cap and have access to fix this.Also I was told there is a cup style seal and o-ring style seal.My manual only has the o-ring style listed.Any help would be appreciated.
Joe (Wa)
11-01-2005 09:33:00
 Re: Vac eagle hitch problems in reply to S.Gross, 11-01-2005 07:01:03
Disconnect the hyd line, remove the allen head bolts and lift the cylinder housing off. The connecting rod nests in a socket in the piston but is not mechanically attached so when you lift the cylinder off, the piston will come off with it, connecting rod remaining attached to the rock shaft.
When the cylinder is detached you may have to use a puff of compressed air applied to the hyd fitting to blow the piston out of the cylinder. Check the cylinder for scoring, you may have to clean it up as in honing.
1950 should have a leather cup, however, either the cup or the o-ring piston will fit the cylinder so it may have been changed, eyeball the piston before you order parts.
Leather cup is available aftermarket and from Case: Original Case p/n VTA1582 cross-ref p/n A30798.
If O-ring seals (2). Still available from Case or a hydraulic shop.
Original Case p/n V20353 cross-ref p/n A30757.
Joe
Rob K
11-01-2005 09:25:49
Hey, I had the same problem as you this summer. It's easy to fix. Remove the allen bolts (1/2 inch) and the fluid input/outlet tube and lift off the piston tube. Be carefull; the piston is not attached to the piston rod, so it could fall on your foot. On top of the piston is either the cup or the o-ring. Mine is a 1950 also, and it had the cup so yours probably has the cup. You can order the part from case. I can't remember the part number, but if you search back through the archives you should be able to find it from when it was given to me.
This page will show you most of what you need to know:
Link
See also: Link
