case model 310 sn 6078479
mike mcmurray
10-31-2005 16:08:45
Hey there all! Just pulled a case 310 tractor out of a field up here in NH. Are there any tricks to getting the oil pan off? It appears to be lodged in there pretty good. Thanks, Mike McMurray in NH.
Joe (Wa)
10-31-2005 16:26:49
 Re: case model 310 sn 6078479 in reply to mike mcmurray, 10-31-2005 16:08:45
You have to drop the rear steering pivot bracket to remove the two bolts on the back of the pan.
Can't remember if the front pivot surpport has to be dropped or not.
When I did mine, I just unbolted the whole steering gear and wheeled it out of the way. Course I was doing an engine out of frame overhaul, replacing the clutch, etc.
Joe
wayne2
10-31-2005 20:24:28
 Re: case model 310 sn 6078479 in reply to Joe (Wa), 10-31-2005 16:26:49
Listen to Joe, myself, when Dist.froze in 320 B-Hoe had it upside down no problems. except lot of work!! LOL W
Larry Shephers
05-26-2006 16:16:34
 Re: case model 310 sn 6078479 in reply to wayne2, 10-31-2005 20:24:28
Hi Joe,
I have just bought a Case Model 310 serie: 6078207
and I would like to know where I can gets pictures so I may refurbish it. Can you help me6
Larry
