Still working on 400 hydraulics
Larry
10-25-1999 20:29:45
Havn't got a reply on my hydraulic problem yet.Has anyone besides me ever had any trouble with this? Went over everything in the I&T book and still can't find the problem.Talked to Case machanic and he thinks that the info in book could be wrong about the right hand valve head.He says that he ran into a problem one time and did everything acording to the book.Turned out the book was wrong,but he can't remember any of the details.The thing I have been woking on is trying to get down preasure on the eagle hitch.I think it might have something to do with the auxilery spools(pins),but can,t but my finger on the problem.Please can any one help????
Larry
10-26-1999 20:57:04
 Re: Still working on 400 hydraulics in reply to Larry, 10-25-1999 20:29:45
I'm about to set fire to this thing!!!! Please anybody HEEELLLLLPPPPP!!!!! !
Jerrie Lott
10-28-1999 18:46:48
 Re: Re: Still working on 400 hydraulics in reply to Larry, 10-26-1999 20:57:04
I don't think the Eagle hitch was designed to have down pressure I can't think of any three point hitches that have down pressure. I suppose if you can find a ram off of an older model SC without Eagle hitch and it is the same length you might get it to work, they were a double acting cylinder, I know because I grew up on one and when you lowered the cultivator, it sucked it down until the ram was fully closed and the hydraulic lever popped back to center with a rather distinct sound. Why do you need down pressure on your Eagle hitch anyhow?
Larry
10-28-1999 21:28:58
 Re: Re: Re: Still working on 400 hydraulics in reply to Jerrie Lott, 10-28-1999 18:46:48
The 400s have a double acting cylindar on them.The control valve has a power down and a float posision.You need down preasure for the same reason you did on the SC Case.When I used to run this tractor when I was in High Scool it had down preasure.We used it on the Case subsoiler and a few other things.I might not ever need it but I'm a fussy old s.o.b and I like things to work the way they are suposed to.I put this project on the back burner for now.I'll get back to it latter.I'll never give up.(Bull headed ain't I)
Jerrie Lott
10-30-1999 17:36:47
 Re: Re: Re: Re: Still working on 400 hydraulics in reply to Larry, 10-28-1999 21:28:58
There must be something in the spool that is goofed up or missing, I'm not sure how it is configured, but maybe there is an O-ring missing that is allowing the oil to by pass all the time thus putting it in float, Just a thought.
