Planetary Gears
RPoff
10-31-2005 04:28:00
Mornin' yall. I have a DB 885, and it has planetary gears as the drive/powertrain. What do I fill the reservoir around each set of gears with? Will regular 80-90 ger oil work, or do I need something different? Thanks,
Rob
Baz
10-31-2005 20:36:18
 Re: Planetary Gears in reply to RPoff, 10-31-2005 04:28:00
I guess it is your outer final drive hubs, These are actually a spur pinion and bull gear set up. 80w90 is OK if you have that at home. We use 85w140.
Barry.
RPoff
11-01-2005 04:40:44
 Re: Planetary Gears in reply to Baz, 10-31-2005 20:36:18
Thanks Barry!
