VAC belt pulley
Tom Railsback
10-30-2005 17:19:49
A friend of mine has a 1951 VAC with belt pulley. He needs to know how to engage the pulley. Is it true that you loosen a setscrew and slide the pulley in or out on the shaft?
also Herb
10-31-2005 04:14:50
 Re: VAC belt pulley in reply to Tom Railsback, 10-30-2005 17:19:49
Hi Tom, if it has not been moved recently it might require a lot of effort to move.
Cases n Harleys
10-30-2005 22:23:29
Yes the set screw theory is true,if Your on the right side looking at the pulley You will see a set screw on top the pulley shaft housing at the 12 o'clock position, loosen the jam nut and then the set screw, keep in mind if the engine is running it will make a pretzel out of you. push straight in on the pulley as if trying to push it under the dash and the gears will mesh together,the gears fit together just like spider gears in a differental. most va's have a lock on the clutch pedal that rolls around and jams against the left running board holding the clutch pedal down when the engine is running(make sure clutch is adjusted properly) if trying this.good luck. Jim
Joe (Wa)
10-30-2005 20:46:43
Yeah should do that. Go to link, click on page G3 F1 at the bottom.
Joe
Tom Railsback
10-31-2005 10:33:21
 Re: VAC belt pulley in reply to Joe (Wa), 10-30-2005 20:46:43
Thanks guys.
Tom
Alberta Mike
11-01-2005 06:01:49
 Re: VAC belt pulley in reply to Tom Railsback, 10-31-2005 10:33:21
Don't engage it when it's running for starters. You might have to do a bit of wiggling to get it to mesh but it's best done while not running. After the mesh is made, the lock bolt must be turned inwards again to lock the sliding cylinder inside. There are two tapered lock holes in that cylinder that the locking bolt goes into. If you take out the locking bolt, you'll see the end is tapered. Anyways, one of these holes is to hold it in the disengaged position (like it is now) and then the other holds it in the engaged position when you are using the pulley.
