gasoline in the oil
Gordon Hoover
10-30-2005 08:52:07
I bought a used 530CK from an individual. Checked the oil (it was fine) and ran it for about an hour and it quit. I pulled the plugs and when I spun the engine, #1 cylinder spouted raw gasoline. I checked the oil and the crankcase was full of gasoline. Local mechanic told me to pull the head, but I don't see how a damaged head could fill the cylinder and crankcase with gas. If the carb (float) was maladjusted could the sidedraft pull that much gas up? Any ideas? Thanks
Tony in Ohio
11-01-2005 13:07:47
 Re: gasoline in the oil in reply to Gordon Hoover, 10-30-2005 08:52:07
It could be a bad fuel pump. If the diaframe is busted the gas can go right into the oil pan.
Gordon Hoover
11-01-2005 21:10:54
 Re: gasoline in the oil in reply to Tony in Ohio, 11-01-2005 13:07:47
Thanks for the post, but it's a gravity feed fuel system...no fuel pump.
TimBinWV
10-30-2005 11:29:47
Does the motor have a gravity feed to the carb or a pump?If there's a pump,there's a diaphram in the pump that can leak into the crankcase.Dunno how that much gas could get into the #1cyl. And stay. Unless both valves in that cyl were not operating,then there would be no way to exhaust unspent fuel. Try checking points/rotor to make sure the cam is still turning.
Gordon Hoover
10-30-2005 18:16:07
 Re: gasoline in the oil in reply to TimBinWV, 10-30-2005 11:29:47
It has a gravity feed to the carb. Engine ran until the fuel filled #1 cyl and stopped the engine rotation. (fuel wouldn't compress, of course) Rotor turns. Only way I can think fuel got to crankcase was past the rings in #1 cyl. It just couldn't pass the rings quite as fast as it was coming into the combustion chamber. Is my reasoning faulty? Or am I missing something? Thanks for the post, by the way.
Gordon
Erik KY
10-31-2005 10:21:39
 Re: gasoline in the oil in reply to Gordon Hoover, 10-30-2005 18:16:07
I have a theory- Take the air intake hose loose from the back of the carb and see if gas pours out. I am guessing that the float stuck in the carb and the whole carb filled with gas enough so that a large gulp of gasoline was sucked into the engine. The gas in the crankcase probably seeped past the rings of the other 3 cylinders in the minutes/hours after the motor sucked in that big slug of gas and died.
How was the oil pressure before it died- if the oil pressure was pretty good then there probably wasn't any gas in the oil at that time.
My old SC carb's gas float sticks from time to time and gas pours out of a tiny crack between the carb and air intake hose that connects the carb to the air filter.
Gordon Hoover
10-31-2005 14:26:28
 Re: gasoline in the oil in reply to Erik KY, 10-31-2005 10:21:39
I think you nailed it. Thanks a bunch!
Gordon
