What Size Rear Tires on LA?
TMAC
10-25-1999 19:47:53
I have a non-running LA with junk tires. The rear tires are 18.4 - 30. I am looking for usable replacements and I'm wanting to know if this is the correct size or are there other sizes that will work?
Al Kirmer
11-03-1999 14:49:23
 Re: What Size Rear Tires on LA? in reply to TMAC, 10-25-1999 19:47:53
LA's and L's typically had 15x30 and 14x30 rear tires. If yours has 18.4x30 that means someone had the rear rims widened by 4 inches so they would fit. This was a common practice to get more traction by putting a wider tire on the ground. If your rims have been widened then you will need to stay with the 18.4x30 tires. My LA has had the rims widened and has 18.4x 30 tires on it. The only way you can put 15x30 tires like original on it is to go back to the narrower rims.
Shaun In wisconsin
10-26-1999 15:46:42
15-30 is truly the factory spec size somtimes farmers put larger sized tires on for more traction
